2.4" TFT Handheld Pocket-size Digital Oscilloscope
Finding our Happy
New Member
Nov 27, 2018
12
11
3
52
Ok I am completely new to using a scope so bear with me. I ran across this and thought it would 1. be cool to build 2. A great learning project 3. If it would let me look at the wave form after turning up modulation on a cb it would get me started.
Now that being said would it work for entry level or not. If not can you explain why so I better understand.
70 mhz and above is recommended for cb radios.
I belive from the specs this one is 0-200khz but i dont see the MHZ listing
Specifications:
DSO138 Kit
Type: NOT Soldered DIY Kit / SMD Soldered Kit (Optional)
Maximum Real-time Sampling Rate: 1Msps
Accuracy: 12Bit
Sampling Buffer Depth: 1024 bytes
Analog Bandwidth: 0-200KHz
Vertical Sensitivity: 10mV / Div - 5V / Div (1-2-5 progressive manner)
Input Impedance: 1MΩ
Maximum Input Voltage: 50Vpp (1: 1 probe), 400Vpp (10: 1 probe)
Coupling Modes: DC / AC / GND
The Horizontal Time Base Range: 10μs / Div - 50s / Div (1-2-5 progressive manner)
Supply Voltage: DC 9V
PCB Size: 117 * 76mm / 4.6 * 3in
Screen Size: 52 * 40mm / 2 * 1.57in
Package Size: 18 * 12.5 * 3cm / 7.08 * 4.92 * 1.18in
Package Weight: 119g / 4.21oz
