2 pill amplifiers...
Oatmeal
484
78
38
West Virginia..
I'd like to know something about these 2 different size 2 pill amps...
One has the 2290's in it.....the other has 2879's in it...
I want to know, what kinds and size tube amps can these amps be used with for a driver ?..
What brand or name amplifiers are they? Reason being there are big differences, palomar, texas star, x-force, and then different classes. Would it be best to drive a tube amp with another smaller tube amp?
Reactions: 2 people
A 2 pill like to try a DM or maybe a BM Technology amp...
Kinda doubt it been a XF amp..
Or maybe a JB 12 or 15 modulator...
Used to run a JB 12 years ago..
I personally dont like to drive an amp with another amp. I would go with a high powered radio to "drive" a HD amp. Maybe a 1-pill though.
1)Stability. How is an outboard amp more stable than an inboard amp?
2)Less chance of over-driving. That's operator error.
3)Better control of power. See#2
4)Less mess connecting things up. See#2
5)Less chance of things going wrong. See#2
6)Generally lower power consumption. I can't see that personally.
I did the high power radio thing a few years ago, an external driver is a lot more flexible in my opinion.
Originally Posted by Captain Kilowatt
1)Stability. How is an outboard amp more stable than an inboard amp? [/quote]
More tuned circuits interacting in the presence of upset impedances or RF fields. More common that you may think.
5)Less chance of things going wrong. See#2 [/quote]
True but nevertheless a consideration. You asked how it was different. this takes that issue out of the mix.
You can't. I can. Add up all the stages and efficiencies and how much TOTAL power is being generated to produce that final output number and see.
I always thought that driving a big amp with a high powered radio reduced potential impedance mismatches that could occur when running 1 amp into another amp.... maybe I'm wrong in my thinking, but that's kind of a rule I've always lived by. :confused1:
~Cheers~
sure, there are more than one way to skin a cat, but there is only one way to scrub a cheese grater. :whistle:
anyway, to put it another way- linear amplifiers do not like to be connected to coaxial cables.
