20m 1/4 vertical... ground mount? 1/4 wave above ground or higher?
mr_fx
Sr. Member
Oct 8, 2011
1,536
172
173
Kansas City
I would be making tuned radials if I mount it in grond if it is ground mounted, and several on the ground
ideas? comments?
No real need for tuned radials if the antenna is ground mounted. Just put in as many as you can and make them as long as you can. Lots of shorter ones (not too short) are better than a few longer ones. If you mount it above ground by any amount it would be better to used tuned radials and you do not need very many at all. Four will be a good starting point.
