29 NW LTD Classic - Red light but no output or meter movement on TX
JDE
New Member
Feb 9, 2022
77
20
8
40
Got this radio in the other day. Looks like it was used in a dusty environment, perhaps a lot of gravel road driving. It did rx and tx, but dimmer knob was pretty bad. Ran CRC QD Cleaner in all the pots and switches, everything worked great, even the meter and nightwatch illumination.
I cleaned up a few ugly solder joints on the foil side, then removed the meter hold-down plates to move the meter back / replace bulb with LED / reinstalled meter. Everything still works, but now on TX I only get the red TX light but nothing on meter and nothing on the Bird 43. I checked and re-checked the area around the meter to make sure I didn't knock anything loose, checked the 3-4 solder joints I fixed to make sure they were good and no shorts, nothing is overheating or smoking, etc. Can't figure out what happened.
Based on those symptoms, where should I start looking? Still new to this and learning the ropes. Can get pictures of component and foil sides later today if needed.
