2950 stays in transmit after mic is unkeyed
  • Thread starter Thread starter unfknreal
  • Start date Start date
U
unfknreal
Guest
Hey all... A friend just bought a 2950 (older model) that works great except when you key up and talk, it sometimes stays in transmit mode after you unkey the mic. If you key up a couple times real fast it will unkey itself. Tried a different mic that we know is good and it still does it... is this common? any idea how to fix it?
Thanks
</p>
See if there is a battery for the memory and change it. If it has one, it will most likely be 3 volts. I changed the battery in my Saturn Turbo/2990 to take 2 AA batteries, batteries still have full charge after 1 1/2 years.. Others have recommended changing it to take lithium battery instead. My radio did some unexpected things when the battery went dead. Keying up when changing channel, or when unkeying, freqs not showing up correctly etc....
Triple J
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=triplej@worldwidecbradioclub>Triple J</A> at: 3/12/04 8:15 am
