2SB824 replacement.
Low_Boy...Great, I need one of those punches. Is the Roper Whitney 5 kit good enough for that job or do I need something heavier? Yea, those hard drive magnets are crazy strong. Don’t stick one on the refrigerator without paper between it. Otherwise you might scratch the surface trying to remove it.
That is the kitI have. I also have a Harbor Freight exact copy that I bought 25 years ago. That would probably work for you also. I just have a new thought on things that I do not want to buy junk. I did notice that on e Bay they have come down in price.
Also the punch may be hard to squeeze in to some places but I like using it more than a drill. I have not tried it on aluminum yet.
Thanks! I have my eye on a Whitney. I don't mind removing a few parts to make room if necessary either. I should have stopped drilling holes for switches, jacks, transistors etc years ago. I never realized they made something small and powerful enough to do this job. For some reason all I envisioned was some huge hand leverage item that looked like breaker bar. I see there are a lot of cheap knockoffs of the Whitney, but old school tools become a mater of pride. I once had a nice set of Greenlee punches that I used to make tube socket holes with back in the 60’s. Unfortunately I loaned some of them out and they were never returned. The cost of those is sky high nowadays. Used ones are over twice the price I paid for a new one in the early 60’s.
I have a few ideas but I may be wrong. What would be a good replacement part for a 2SB824?
I have poison ivy and have not slept in 3 days so double check this.
Cross-Reference Search Result (Equivalent Transistors)
↓ Type Mat Struct Pc Vcb Vce Veb Ic Tj Ft Hfe Caps
2SB872 Si PNP 45 60 60 6 8 175 4000 TO220
2SA1293 Si PNP 30 100 80 7 5 150 30 70 TO220
2SA1293Y Si PNP 30 100 80 7 5 150 30 120 TO220
2SA1329 Si PNP 40 80 80 6 12 150 50 70 TO220
2SA1329O Si PNP 40 80 80 6 12 150 50 70 TO220
2SA1329Y Si PNP 40 80 80 6 12 150 50 120 TO220
2SA1452 Si PNP 30 80 80 6 12 175 50 70 TO220
2SA1452A Si PNP 30 80 80 6 12 150 50 70 TO220NIS
2SA1452O Si PNP 30 80 80 6 12 175 50 70 TO220
2SA1452Y Si PNP 30 80 80 6 12 175 50 120 TO220
2SA1726 Si PNP 50 80 6 175 20 160 TO220
2SA1771 Si PNP 30 80 80 14 12 150 50 100 TO220
2SB1078 Si PNP 40 120 120 7 8 175 1000 TO220
2SB1078K Si PNP 40 120 120 7 8 175 1000 TO220
2SB1100 Si PNP 30 100 100 7 10 175 6000 TO220
2SB1106 Si PNP 40 120 120 6 6 175 1000 TO220
2SB1107 Si PNP 40 120 120 6 10 175 5000 TO220
2SB1108 Si PNP 50 120 120 6 8 175 5000 TO220
2SB1252 Si PNP 45 120 120 8 5 175 15000 TO220
2SB1606 Si PNP 40 130 80 7 5 30 90 TO220F
2SB1607 Si PNP 40 130 80 7 7 30 90 TO220F
2SB1686 Si PNP 30 110 110 6 100 5000 TO220F
2SB601 Si PNP 30 100 100 7 5 150 7000 TO220
2SB711 Si PNP 50 80 80 6 10 150 1000 TO220
2SB712 Si PNP 50 100 100 6 10 150 1000 TO220
2SB727 Si PNP 50 120 120 7 6 150 10000 TO220
2SB727K Si PNP 40 120 120 7 6 150 10000 TO220
2SB791 Si PNP 40 120 120 7 8 150 10000 TO220
2SB791K Si PNP 40 120 120 7 8 150 1000 TO220
2SB823 Si PNP 40 100 100 6 6 150 100 TO220
2SB824 Si PNP 30 60 60 6 5 150 15 70 TO220
2SB824Q Si PNP 30 60 60 6 5 150 15 70 TO220
2SB824R Si PNP 30 60 60 6 5 150 15 100 TO220
2SB824S Si PNP 30 60 60 6 5 150 15 140 TO220
2SB862 Si PNP 30 120 120 6 5 150 34 5000 TO220
2SA1293O Si PNP 30 100 80 7 5 150 30 70 TO220
2SB872A Si PNP 45 80 80 6 8 175 4000 TO220
BD566 Si PNP 50 60 60 7 10 150 2000 TO220
BD566A Si PNP 50 80 80 7 10 150 2000 TO220
BDT20 Si PNP 62 130 130 8 150 500 TO220
BDT64 Si PNP 125 60 60 12 150 20 2000 TO220
BDT64A Si PNP 125 80 80 12 150 20 2000 TO220
BDT64B Si PNP 125 100 100 12 150 20 2000 TO220
BDT64C Si PNP 125 120 120 12 150 20 2000 TO220
BDW94CF Si PNP 30 100 100 12 750 TO220F
BDW94CFP Si PNP 33 100 100 12 150 750 TO220FP
ECG2344 Si PNP 125 120 12 150 1000 TO220
ECG55 Si PNP 50 150 150 8 150 85 100 TO220
HBDW94C Si PNP 80 100 100 12 150 750 TO220
HEPS9152 Si PNP 65 60 8 150 1000 TO220
HEPS9153 Si PNP 65 100 8 150 1000 TO220
KSA1010Y Si PNP 40 100 100 7 7 150 100 TO220
KSB1097O Si PNP 30 80 60 7 7 150 70 TO220
KSB1097Y Si PNP 30 80 60 7 7 150 120 TO220
KSB601 Si PNP 30 100 100 7 5 150 8000 TO220
KSB601O Si PNP 30 100 100 7 5 150 5000 TO220
KSB601R Si PNP 30 100 100 7 5 150 3000 TO220
KSB707Y Si PNP 40 80 60 7 7 150 100 TO220
KSB708Y Si PNP 40 80 80 7 7 150 100 TO220
NTE2548 Si PNP 30 110 100 6 8 4000 TO220
SD404 Si PNP 90 60 10 TO220
SD406 Si PNP 90 80 10 TO220
SD408 Si PNP 90 100 10 TO220
SD410 Si PNP 90 120 10 TO220
SD454 Si PNP 90 60 10 TO220
SD456 Si PNP 90 80 10 TO220
SD458 Si PNP 90 100 10 TO220
SD460 Si PNP 90 120 10 TO220
SM2184 Si PNP 80 80 15 200 20 1000 TO220
SM3184 Si PNP 60 80 20 200 20 1000 TO220
TTA1452B Si PNP 30 80 80 6 12 150 50 120 TO220SIS
  • @ Catalyst 122:
