My Palomar 300a has two 6kd6's driving four 6lf6's.
I just got hold of six nos 6kd6's.
Is swapping the four 6lf6's out for the four 6kd6 finals okay?
If so is it a swap that consists of just removing the 6lf6's and plugging in the 6kd6's in without having to do anything else?
I know that some 300a's came with different drivers and finals but I believe this 300a to have the exact numbered tubes it came with from Palomar. They might even be the originals.
If it can be gone by just removing one and putting the others in, would there be any advantage (or disadvantage) to replacing the four 6lf6''s with the 6kd6?
I never tested the 6lf6's myself but I believe them to be good as I get about 450 with 11/2 swining 8/10 on AM which is what I us it on and believe that output to be what the manual calls for. Thanks. Ps If there's no other reason to swap them but for the fact the 6lf6' need to be replaced because it is that time then they'll make for good backup replacements. The were tested on a Hickock tube tester and we're show to be at 90% with other readings. I'm not sure what the other readings mean but they were within the numbers showing there in excellent shape.
