400 Channel AM Midland 95 Plus
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
10,616
12,266
843
Sierra Nevada by Yosemite National Park
Open Radio, removing 2 screws behind battery compartment 2 screws at top and remove single screw on bat cover housing.
Holding radio face down top up prise up on right hand side pcb and lift clear. The rear of the button pcb containing the display now faces you.
Halfway down on the right hand side a block of numbers 1 to 4 and below them are the solder links that format the PLL for CEPT 40ch FM.
Remove all solder links by gently heating link and wiping away solder with soldering iron. Check with a continuity tester that all links are removed.
Reassemble radio and the display will indicate AM and channels will indicate 40A,b,c,d,e,f,g,h,i and L, covering 400 channels.
Reactions: tecnicoloco
