68XL 9/19 switch mod
What IS the 9/19 mod you are referring to?
I have a PC76XL with a CH9/NORMAL switch that allows me to select HI/LO power. In the up (CH9) position I get the 45+ watts high performance mod. In the down (normal) position I key 2 watts in order to run a small amp.
The switch is only used as a switch however.
