$7 for a 0-40MHz Test Generator?
Robb
Honorary Member Silent Key
I Support WorldwideDX.com!
Dec 18, 2008
11,418
3,661
323
Silicon Valley CA, Storm Lake IA
I think if a freq counter kit and a very stable power supply were to be used with it, it would work. The clarity of the freq sine wave changes @40mhz. The square wave will work from 0-1mhz, as the specs say.
Stability and accuracy have to be far better than an analog generator. If you ever owned a cheapie $35 analog generator and used one for radio alignments; then one could appreciate what this board may provide. It may be be a welcome tool - in comparison.
NEW AD9850 DDS signal generator module 0-40MHz 2772
Features:
2 sine wave and 2 square wave output
AD9850: 0-40MHz
After the 20-30MHz frequency harmonics increases, the waveform will be less and less clean
Square Wave: 0-1MHz
Low-pass filter with 70MHz, so the waveform better than SN
Parallel and serial data input can be selected via a jumper
DA produced the benchmark pin (PIN12) leads for easy adjustment to do the magnitude of the output waveform Application
Comparator reference input voltage generated by the variable resistor, the resistor can be adjusted duty cycle square wave of different
Active AD9850 125MHz crystal oscillator modules
Package Contents
100% Brand New
1 x AD9850 DDS signal generator module
Here is a better view:
