98vhp
ALFRED56
Dec 2, 2012
20
NNJ
Well jumped in the truck after being broken for two weeks and Turn the radio on to tally to some friends rx is not the best so I by pass all jumpers to Amp and meter and improves bad jumper. But go to talk and I have no out put power whatsoever any ideas??
if it was left in at a repair shop the finals are more than likely blown from some one platyoing with your radio since you said a jumper was bad.
if you do not have output do you have the means to repair your own radio. since the jumper was bad the finals could be out. the 1st place to check.
if you do not its shop time.
