Hello,
I am attempting to repair a amp of a friend, He ad a mic that would key up by itself. I did repair the mic as it had a loose wire
and would go into transit mode if the floor was bumped. Anyways while he was away from the room the mic keyed and left
the radio WITH the amp engaged for a long time and it was blazing hot. So My question is has anyone seen this amp or a
similar layout for a schematic to look at? And a unrelated question I have read that "some people" have said that the HG transistors
leave a lot to desire, But i would like t know how the MAcom transistors compare to the original Motorola's? They have the same data sheets
i mean identical! So fr any of you how do they compare in use? Are they the same?
Thank you and i look forward to here form you informed guys.
