A few new tubes and no change, what next??
  • Thread starter Thread starter hossless
  • Start date Start date
H
hossless
Guest
Hey all, I replaced several of the very weak tubes in the D&A Warrior 1000 with brand new ones I got for an unbelievable price from a friend here locally. There was no increase in watts. What do I check next? Also, two of the tubes I replaced were very dim, weren't glowing nearly as bright as the other tubes, and no change with the new tubes in those same two tube sockets (still very dim - not glowing as bright as the other 6lq6's). Any suggestions?, or do I need to get this thing into a tube tech??
Thanks, Hossless
</p>
Another "strange" thing, when I go to drain the tubes (touching the cap of the tube to the case of the D&A with a very well insulated screw driver), nothing happens, even when I have just turned the amp off and unplugged everything. It's almost like there is no juice at all in the tubes? Could it be a resistor or maybe a capasitor problem? I have looked at the bottom side of the amp and have found nothing that looks fried.
Thanks, Hossless
</p>
Sounds to me like your capacitors are bad. Had the amp been sitting for a while and not used ? If so the capacitors are probably gone. I would check the capacitance on those first. Back in the 70s and 80s when I ran a Phantom and a Maverick I know when you bled off the capacitors it sounded like a gun going off. If you need capacitors check with RF Parts in California, 1-800-RFPARTS. I hope this helps a little. Good luck,Mike.
</p>
