A few radios forsale
TonyV225
Apr 18, 2005
5,824
331
143
Wisconsin
Have Kenwood TS-50 with Matching AT-50 Automatic Antenna Tuner quick Release Mobile Bracket Both owners Manuals for the Radio and Tuner power cord interface cable for radio to tuner and stock microphone this was my wifes amateur rig it has the Mars mod for full coverage 160 - 10 Meters These are absolutely outstanding radios and run a pair of 2SC2879 Final output transistors in the PA or output section radio has always been run at 100 watts average and shows about 130 watts on a true peak reading meter in the peak mode. Stock mic sounds great on this radio. This radio has some weight to it $600.00 shipped and insured to your door.
RCI 2970 0range display model set at 100 watts also has a switch to turn off inner amplifier to run a separate low drive amplifier comes with stock microphone mounting bracket and power cord radio is about an 8 or so out of a 10 in looks as its going to have some scratches but this radio has been professionally tuned and has the Mars mod it got great on the air reports.$265.00 Shipped and insured to your door
Sommerkamp 2950 Getting scarce to find basically a 2950 has mounting bracket power cord and Microphone Mars mod for full coverage also done to this radio got great on the air reports radio is 8 or so 0ut of a 10 in looks. $225.00 Shipped and insured to your door
Ill always post 7 to 8 on radios regardless and its to hard to judge how the next person does and if its used it certainly isn't mint or new ;)
