so if the top section is proper length then WHY would it be doing this?
gee, page 2 ,..... and no one has said the coax is the wrong lenght
gee, page 2 ,..... and no one has said the coax is the wrong lenght![]()
top section measures 70" but should measure 72"
Either the coax has issues - or where it was mounted.
Probably where it was mounted - IMO . . .
what about a ground wire issue... I was grounded when I was on the roof... not grounded on the floor
If you take it down check the tip length. It should be 72" long if it is stock, and I think the A99 has Antron, Holland, Ohio printed on the plastic cover on top. That might tell you if the length has been changed.
You might also compare you radio bands and see if they all produce about the same RF output using a good dummy load. The SWR may show about the same with such a setup, but the watts could be different. If so, the radio is not tuned right, but if it is not much then, "don't worry about it."
... mounted it about 7 foot above the deck in the back of my neighbor's house... also used about 18 ft of RG58 instead of 65ft of RG8
SWRs dropped in the CB band to around 1.2-1.0 ...
could it I can't see it being coax related... but...
