Adding talk back to a radio
Turbo T
Certified CB Rambo
Feb 2, 2011
963
141
53
I'm interested in adding talk back to my mule, a Midland 77-106. I know it's a matter of soldering a resistor across the PA jack and the EXT SPKR jack.
I just want the talk back to be barely audible over the speaker. In other words, the RX comes thru louder than my voice on TX, over the speaker.
I do not want to have a case of squealing over the airwaves because the talkback is too loud.
And to keep it simple and cheap, I don't want to do a variable talk back; just a fixed talk back.
With that said, I plan to rummage thru Rat Shack's resistors....which one would be the ideal one given my above desires?
Thanks in advance.
just play with the values, if I recall correctly, the closer you get to 0 ohm, the louder it will get.
you can also series in a switch that will kill the talk back if needed.
Variable talk back would be done the same way, however the resistor would be removed and a pot. put in it's place
