Adjusting Browning mark 3 output (plate tuning control) HELP!
darticus
104
4
Anyone able to walk me through making this adjustment to get the most from output? I could also use a pic of the rear of the set as I can't see the back of the set to adjust screw without a big procedure. I can get my hand back there to adjust. Is it on the transmitter or receiver. Thanks Ron
will have to look at mine,but look at the transmitter,and set it to ma...and dont run it over the max on ma...the alc to high will kill your transmitter tubes and also your transformer...will get back to you about it...at one time i had many brownings...73 de JW
Hope to hear back when you get time. Thanks Ron
