set the radio to channel 20.
mic gain at max.
best to use a dummy load, but if your antenna is well tuned it should work ok.
connect wattmeter and antenna to radio.
make sure you use a plastic or wooden tuning tool on the tuning slugs.
using a metal tool such as a jewelers screwdriver will give you false readings and can EASILY break the ferrite core, which will really screw things up.
make sure the tool fits snugly in the slug.
tune in this order for max modulated wattage: L20, L21(both slugs), L17, and L14.
to do this, key the mic, and in a steady voice, say "ahhhh" into the mic while tuning the coil for max reading on your wattmeter.
tune slowly.
you will find a spot that "peaks" the reading and once you go past it, the wattage will start to fall off again.
go back and forth until you find the sweet spot, then leave it there and move on to the next coil.
try not to leave the mic keyed for 5 minutes straight while you do this. LOL
you might find that you get more wattage with the slug from L14 removed, so try tuning it and then try removing it to see which is better.
DO NOT spread any of the coils back there.
they will not increase your power, even though your meter may say they do.
they are harmonic filters and messing with them can make your radio bleed on every clock and toaster in the neighborhood.
there is much more to that explanation, but that is the short version.
after doing all this, while saying "ahhh" into the mic, turn VR4 counter clockwise until you see that the wattage is not increasing any more.
leave it there.
no need to turn it all the way up, just turn it up until it does no more good and leave it.
good luck,
