Ameritron AL-80
Wayne, here is a link to the Mods for The Ameritron amps, but it looks like the early amp is going to require some more in-depth work
I found this in a review on E-Ham:
<blockquote>Quote:<hr> I added the factory supplied 10 meter kit,<hr></blockquote>
(FYI, I am Jeff, he is Mole LOL! )
Here is a list of mods:
Ameritron Amp Mods Click HERE......
It says for the AL-80(not A) to write
His E mail is
[email]y40002000@yahoo.com <y40002000@yahoo.com>[/email]
Hope that is of some help.
<span style="color:orange;font-family:helvetica;font-size:large;">RadioActive</span>
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=audioshockwav>AudioShockwav</A> at: 1/20/05 6:23 pm
Wait nooo...I'm Jeff, I am me. and you are him,and he is Mole?
<img src=http://www.wwdx.org/smilies/Confused2.gif ALT=":confused2">
</p>
Uhh, no I am Jeff, He is Wayne and "HE" is Mole.....I am cornfusezed.........I Think?????
<img src=http://home.comcast.net/~shockwav/food_477.gif ALT=":crncndy">
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=audioshockwav>AudioShockwav</A> at: 1/20/05 2:34 pm
Ahh....he HIM is Mole, He YOU are Jeff, Me is Jeff and HE is Wayne?
I GOT IT...wow..sleep deprivation ...ugh
WAYNE...snows here....better fire those amps up to melt it!
</p>
Is it modifiable for 10 meters, if so how difficult is the mod?
Wayne C.
CDX-787,AK-2787
mobile/base
Magna Force 900
HR2510/HR2600
MR. COILY 32 inch mast Single Coil/Wolf .64 ground plane
D104M6B/Turner +3 desk
Every man is a damn fool for at least 5 minutes every day; wisdom consists in not exceeding the limit.
</p>
<img src=http://www.wwdx.org/smilies/wav.gif ALT=":wav">
<img src=http://www.wwdx.org/smilies/posticon27.gif ALT=":27"> <img src=http://www.wwdx.org/smilies/posticon28.gif ALT=":28"> <img src=http://www.wwdx.org/smilies/wavey.gif ALT=":wavey">
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=bcrewcaptain>bcrewcaptain</A> at: 2/25/05 5:34 am
His E mail is
I am assuming for AM work you would use the CW position correct...
Unless you modify it for lower 'idle' current, YES. The tube heat will get out of hand on AM if you run it on "SSB" mode with the stock zero-signal current draw (idle current) on the tube.
We use a series string of 30 rectifier diodes to take the place of a zener diode. More robust, and the 3-500Z only shows color with drive. Stock "SSB" bias current will put a couple hundred Watts or so on the tube with no drive. Putting it on the "CW" position will keep the heat from the AM carrier from getting out of hand if the tube's bias is factory-stock.
Thanks... I never used an HF amp for other things if you know what I mean... But I assumed that the CW Pos. would be the choice for AM work...
I was looking at getting a BIG Ameritron... :D (AL-800H)
Thank you.
