amp install q for the mobile
Se7en
Jun 27, 2010
4,573
223
Ca
got 1 foot 4awg pigtails off my tsdx500v, is it ok if i get some 6awg wire from batt to amp?
i doubt the ts500 has 4 gauge from factory .you added it?or someone else did ?
from factory it probably has 6 or 8 gauge so i think you would be fine with 6 gauge for that amp .
if you plan to move up in amp size in the future then run some 4 gauge now and avoid a redo down the line .
yes i added the 4 awg pigtails. i went and bought 6' of 4awg from batt to amp. working good. even on my single mag mount wilson 5k:)
i am driving amp with s45hp about 75ish or so watts into the amp since i don't know how to turn down the swing and i tried to use the mic gain which don't help none. even tho this is wrong meter shows 700w in the real world amp maybe doing 500w
