amp recomondations for a rci 2970 dx
madmax
Oct 7, 2008
16
i want to get a 16 pill texas star amp to run with my rci 2970 but not sure if it will work corectly and would appresheat any edvice or recomndation for other amps i will be running it in my ex cab f250 also leav a handal and ill try to get you an the radio som time
That would be a pretty good match there as you've described, it could stand a little more but it should last forever with that radio and ssb would be decent.
and the handle is already there. 43 round the rockies.
good luck finding that amp . killer set up if you can find it though ! what antenna are you running and what kind of mount ?
somtimes i run my wilson 5000 2 of thouse or i run my wilson 5 foot fiberglass wips 2 of thouse also i run the glass in the winter cause i plow with the truck comershaly and you kan find them all over the internet at least last time i checked
