An antenna is just an antenna
nfsus
Yeah its turned off, touch it
May 9, 2011
606
324
Arkansas
I’ve spent quite a bit of time reading, building and wondering about vertical antennas. I’ve raised them and I’ve lowered them. I’ve tried 1/4, 1/2 and 5/8 wave.
All things considered, it don’t matter just a whole lot really what antenna you use once you’re off the ground. On the ground or at low heights it matters but once you clear about 40ft they all start to pull in and act about the same.
I know everyone is gonna whine and claim their super penetrator or their imax is special but truth is I just don’t buy it. Each might model some little quirk at 2 degrees difference or so but that’s just number manipulation based on ground effects or some choke or some plated platinum aluminum snake oil.
Way back when I had an a99 then I bought the ground kit and then I did this and that. All because I had read in a copper catalog that it was the berries. It never did anything substantial but I thought it was better. Fast forward years and I kept reading and trying. Never really gaining any substantive gains. A little here and there. Not much.
I’ve finally settled that a simple dipole is prob the best if you can crank it up in the air. If you can’t get it up very high then snake oil it is and just keep buying into all the hype and maybe you’ll see some differences. Maybe you’ll imagine some.
One of the most radiation-efficient designs going and the basis for many multi-element designs. But you can't sell them on this forum since they're considered weak compared to all the snake-oil models with phony gain numbers sold on Sleaze-Bay. Basic antenna knowledge can help one avoid drinking the snake-oil.
7 3
@nfus, I can imagine you must have had some fun to reach that conclusion. That is what its all about, testing...comparing ...gathering facts.. time well spend !
(And ps you are right, it is hard to beat the center fed dipole ! )
Reactions: nfsus
