How much taller would the iMax 2000 have to be to be able to operate at .64 wave and operate on as low as 20m maybe 30m. Since it is .64 for 11m on @27.000.00.
... want to favor 20m about center band @14.175...
I'll be "gentile",........... if you have privileges on 14.175, you should know the answer already.![]()
I understand that but if I change the mid and top sections what .64 calculation would I need to get .64 wave at in 20m to go 40m 60m 30m 20m 17m 15m ect like if stock out of box .64 = @26.750.00 and is usable without a tuner on 10m 11m 12m 15m and part of 17m, but it favors 11m for .64 want to favor 20m about center band @14.175. I hope I am relaying this right if anyone understands what I am seeking to do, also the top part that the mid section screws into that silver( chrome like ) cap, ode like to know we're to get those to put over fiberglass pipe or pic pipe to screw in like that. Any help will be appreciated on sites that have these things and ideas on what to do to accomplish this.
Thanks
I know a couple of locals that run the Comet CHA-250, and even though the company claimes it works 80-10, both guys say it barely works on 40 for them. 15 and 10 are ok, and 20 is so-so. The thing is only 22 feet long, I think!
If you're looking to use what you have, keep the Imax for 10 and 12 (I know you just got a tuner).Make a wire antenna for the low bands you are trying to hit. A dipole (or inverted V if you're space limited). You can droop dipole ends, too if you need to. I'm still learning this stuff myself, there are lots of books (ARRL) and even Hamsphere and other sites have a lot of other designs that might work well for you. I ended up with an end fed that really is too short, but it works, and I am able to work 75 with it. My delta loop is good for 40-10. I have found that the tried and true stuff is indeed "tried and true", and that's why so many people use them. They work! Stay away from all-bandlow swr no tuner snake oil antennas. They don't work... except to take money out of your wallet.
73,
Brett
