Got another Galaxy Saturn on the desk today.
Issue:
Keeps blowing finals.
Evaluation:
Passthrough regulator is fine.
AF regulator is fine.
Pre-driver is fine.
Driver is fine.
Replaced both finals with good ones.
No swing mods.
Output caps test as good.
All traces have firm joints.
Bias diodes across driver/finals test good.
Both final bias VR adjustments replaced.
Driver bias adjustment tests as fine.
Resistors in bias section look good, and test as fine.
Bias Inductors look and test as good.
With all driver/final leads soldered to their respective pads, I get 0.037 ohms resistance when probing the emitter and base of the finals, but I get around .654 ohms when probing the emitter and base of the driver.
If I lift the collector of all three and probe emitter to base of all three again, same result.
That's with meter in 200/speaker mode not diode mode. Flip the meter into diode mode and they check out as they should.
With everything hooked up, the driver pulls 50ma without even turning it's bias VR off the zero spot. The first final pulls 500ma with bias VR all the way down to zero, both the first and last final both pull around 984ma with both bias VR adjustments turned all the way down.
100 ohm variables for finals, 1000 ohm variable for driver. All three test well within range.
Receive and everything else works great on this rig, just the output stage drawing too much current without any bias adjustment on any of the three bias adjustment VR's.
Issue:
Evaluation:
Pre-driver is fine.
Driver is fine.
No swing mods.
