Already been there. Even posted his video for a puck mount in a previous postCheck out Breedlovemounts.com
They have a great assortment of mounts. Superb quality.
There's another dude that makes them. Not sure if he's still around.
Calles Gunny Puck
Coily makes risers and 102" tune stick which you will like much better than that riser. Gives you 9" of adjustment
Remember that you posted this is CB antennas, don't get too many inquires for NMO mounts for CB radios...
But since you brought up LARSEN - are you using one for 10 meter or CB?
NMO is low loss mount designed by Motorola for their part in making antenna systems and mounts for effective connections in which to BROADEN the surface area that will bear loads - like wind - overhangs - typical abuse antennas get in mobile environments. There are other factors like insulator spacing and lifetime connection losses incurred thru quick disconnects versus permanent thru shaft mounts.
You may have already experienced the "broken bolt" from a 3/8-24" stud snapping off or have a big hole torn into your roofline or the Mag mount magnet "cracking" in two because of the stress and torque you get from the whipping effects of motion...
So if they are recommending you to use an NMO - that's good question as to the why - for most of the CB realm has used, as far as most effective, not necessarily efficient - mounts have been to use the 3/8-24" approach.
When it comes to LARSEN, they don't normally cater to the 11 meter crowd - but I imagine they had a good reason to tell you to switch to an NMO mount...if your an Amateur looking for low-loss swappable mounts.
So I'm curious as to what you told them in what you wanted to install?
I had originally started with a thread about adding a grounding strap to the current setup. And things ballooned from there. And I started a side conversation with slowmover asking questions and what not. Like your signature says this has been all about the research and to gain knowledge. 18 year old me didn't have much back then. My wiser older coworker spoon fed me everything I needed to get up and running. He wrote the list I took to the radio shop in Newington Ct, i grew up outside of Hartford Ct, handed it to the guy and said "my buddy Dirty Harry" said to ask for you and to hand you this list. I hooked everything up and went about my business. I didn't ask questions back then, I should have. Now at 42 I've learned and I am able to wait and prepare for a project.Wow, ok, two birds, and didn't even need the stone!
Ok, so the NMO is viable for you.
Also good to know about the mounting - at least you know where you're headed...
As far as NMO mounts and "plate thickness" if you can spare any extra metal up there of 22AWG thickness or greater, that goes a long way is beefing up the mount the larger the sheet you can fit in between the NMO's top and your trucks finish metal (internally) - to the NMO ring that "screws in and bites metal" will help immensely.
A Punch as per @Slowmover - is a necessity to get a clean cut without too many burrs.
Ok, guys, I'll be back in the bushes - with the birds...
