Antenna Switch Box
Ham Radio Nerd
Apr 14, 2002
9,296
1,935
283
If you like a manual switch, the Daiwa switches are great. You can get them at HRO. If you want an autoswitch, the Alpha Delta looks pretty cool, but I've never used one personally.
</p>
Jeff, are those switches able to do bi-directional? I.E... two radios to one antenna. Most I've noticed list using one radio to different antenna coax. Just curious if it was mentioned in the owners papers.
Thanks,
CDX-350
2AK3350
</p>
You can use the Daiwa switches either direction...I do. I have one that switches between antennas, and have another one that switches between radios. You can also order them from www.hamradio.com.
I had some cheap switches for a while that I was using to switch between radios. They were so junky that when I switched, I could still hear stations through the "off" radio. Also, my swr with them inline went up a couple ticks. I took 'em out and put the Daiwa's in, and I'll never go back.
</p>
What makes for a descent switchbox ? I had a dosy and never really had any problems but was looking for something better.....I noticed Maco has a couple, Are they any good ?
_________________________________________________
Thanks for any help, Jim
</p>
