Anyone know where to find...
W5LZ
Crotchety Old Bastard
Apr 8, 2005
6,832
919
173
Oklahoma
It's been a while, but I remember seeing a full wave loop for 10/11 meters that was mounted vertically and quite a bit 'taller' than it was 'wide'. If I remember correctly the input impedance of the thing was very close to 50 ohms, or was easily matched with a 'Q' section. It has to have been in one of the ARRL's antenna books or the handbook. No idea which edition of either. Anyone else remember that @#$ thing, and where to find it? I'm really tired of thumbing through books looking for it. Actually, I'm tired of getting distracted by something else and forgetting what the @#$$ I was supposed to be looking for to start with!
QRN,
No, it wasn't one of those, but thanks for the links, I've got something else to play with! The thing was a very simple 'vertical' loop, nothing fancy at all. There was some kind of particular relationship between H x W, but I can't remember what that was. That's the only reason I'm looking for it, want to know what that HxW ratio thingy is/was, and why it worked. One of those, "If the thing is so fantastic, why ain't everybody got one?", kind'a things you know?
hey W5LZ i thought you might like this picture.i originally used the 1005/frequency=length and after talking to a ham buddy and reading around my conclusion was that 468/frequency*2=length seemed much easier.this loop was meant for the top of 27 mhz and i started at about 36.5 feet with 9 ft feedline and after the new formula cut it down to about 33 feet.i know a full wave is 32 feet and i might end up there however i took your advise and shortened the feedline to 5.7 feet thanks for that.match is around 1.2-1.3 or flat after it rains.its currently about 10 feet of the ground on the addition and talks local 60+ miles i talked all over the us on it this last week.i will trim it down some and i am thinking of mouting it vertical do you know if it would radiate from the sides(wires) or front/back.
Glad it workd for you.
A loop can be directional. Typically, it's bi-directional looking through the thing like an aiming circle, if it's stood up straight. Nulls in line with the sides of the thing.
And to make it just a bit more 'fun', by varying the lengths of the sides versus the top/bottom lengths, you can change the radiation pattern sort of quite a bit, especially if the thing is horizontal, or laying down. And if you want to get a bit more ambitious, making the thing a multiple of a full wave length and varying it's dimensions changes things even more (including it's input impedance so it ain't 'dead' easy, and you always 'pay' for what you get :)).
Any full wave delta loop design will work in pretty much any shape. The most efficient pattern though is when the loop is basically a circle. The most evenly covered interior space is desirable.
You can run them as a delta, equilateral triangle, or a rectangle or a square etc etc, it just shifts the patterns around a bit.
A 20m full wave loop would work pretty nicely for 10m and give you 20/17/12 along with it if you feed it with ladder line and use a manual tuner with it. At two wavelengths for 10m, the pattern would be pretty even still.
as you probably noticed i did not have room to do a circle on my addition but i could do a circle on the main roof however it would be an angled circle about 45 degrees tilted east hmmm i wonder how that would work.i will try it thanks.
Yeah doesn't have to be a circle, the concept is to encompass as much area evenly inside the loop as possible with circle as the ideal. 99% of people with loops are nowhere near a circle, thus deltas and rectangles all over the place.
The only rule I've found that is consistent with wire antennas so far is, more wire, higher up, has always worked better ;-). For backyard antenna builders unless they have 100+ foot trees to use...I think that will hold pretty steady.
