Anytime AT-5555 frequency ranges pre/post mod??
CB590
W9WDX Member
Jun 29, 2016
1,541
1,259
173
Trenton Nj
www.590dx.com
Does anyone have a list of bands A-F by frequency ranges??
Also anyone with an export modification done can you post A-F ranges as well?
The Lincoln + runs like band L,K,G,E,C,A,B,D,F,H,I,J to go from 24.715-30.105 if you want to go in frequency order..
Does the 5555 go A-F straight??
original at5555 or a at5555N ?
original at5555 is 25.615-28.305 bands a-f as normal export arrangement after the mod
however the 6 bands can do anywhere between 25.165-30.105mhz if you alter the channel layout in the pc program...and thats in any order ..like you can set it up for all bands to be 26.965-27.405mhz if you want put uk 40 in one band..usa 40 in another..nz 40 in another..german band in another etc etc
before mod its 28-29.700 factory stock
the at5555n is set up the same way
The Lincoln's frequencies jumps around in non sequential order relative to the band letter.
You'll figure it out. It basically jumps from high side to low side of CB for easy free banding.
