Anytone 5555 clone same radio just different name
You do it in the service menu. I did it to mine but I don't remember which setting it was............I did however find the info here on WWDX somewhere!
I DON'T recommend others messing with the service menu as we have had a number of members now who bricked their radios trying to do this. If you go ahead, write down ALL the service menu values first. Then change the values of ONLY the AM deadkey setting; some of the other settings require expensive equipment (such as a Signal Generator) to set. If you change them and don't have the required equipment you will brick the radio. Proceed at your own risk!
Did a search on the search feature of this forum, here is a link. Click it to read the entire thread.
