Unfortunantly I am stuck on 1st floor of an apartment wich is on the south side of the building facing away from sunset . Anyone have any ideas on what I can do to be able to get in. Keep in mind they dont alow outside antenas.
Eventually there will be multiple receivers spread around So Cal. I know they were looking at Moreno Valley or Box Springs which would probably help in your case.
If you had a crossbanding dual band radio in your car with a decent antenna, you could easily talk on an HT from your apartment to the car, and from the car to Sunset.
Perhaps a small beam pointing to the running springs input, or a small uhf beam pointed to the hill from indoors.
Other than that a dipole outside made from that lacquered wire you wind transformers with is an option (its what i use for my 10m stuff). Try a dipole or small j pole made from transformer wire?
I did some antenna expieraments the other day using an upgraded HT antenna, a 2mtr yagi and 2 diffrent mag mounts. Ironicly the best signal I got was from the HT antenna. the 2mtr yagi came in well to. BTW if anyone has a good duel band magmount for sale IM me.
