ARRL to FCC: Amateurs and Vehicular Radars Can Play Nicely Together on 77-81 GHz
ARRL
Nov 15, 2008
11,045
54
58
In comments filed on April 6 in response to a February FCC Notice of Proposed Rulemaking and Reconsideration Order (NPRM&RO) in ET Docket 15-26, the ARRL has told the Commission that it should make no change in the Amateur Radio allocation at 76-81 GHz and impose no additional regulatory constraints on Amateur or Amateur-Satellite uses of the band. The League said the FCC should proceed with au...
Continue reading...
