Aug 10-11 Summer Contests Rules
binrat
WDX Club Coordinator
Staff member
I Support WorldwideDX.com!
Nov 5, 2008
2,619
1,538
173
The Great White north
Gang,
Here they are, have a look. If you are needing a number post up in that thread. Concerns and questions only please.
Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread located http://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 20-29 AM, 30-39 LSB
  • Date/Time: 0001 10 Aug – 2359 11 Aug 2019 UTC. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • 1 point per contact if your station is in your shack.
    2 points if you are on your patio / deck, antenna maybe your normal antenna but the operating position is not in your shack.
    2 points if mobile,
    3 points if portable in a park, antenna maybe mounted to your vehicle
    4 points if your are portable with antenna not mounted to your vehicle, a POTA or SOTA. Make sure you clearly designate these in your log
  • No amplifiers allowed, CB legal limit.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rule.
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
