awi on 2 radio
1iwilly
Dec 7, 2008
915
653
103
63
hello to all
my issue is with a cobra 29 ltd classic and a trc-427 barefoot radio works fine no light comes on but when i turn on my solid-state 2 pill base amp the antenna warning light comes on ?? no bad jumpers when i use my 148 or 2000 no issues with the amp on only with those 2 radios. i disconnect the antenna wire and connected my dummy load the ant light still comes on any advice, amp is still in factory original condition
hello to all
What kind of amp is it? I guess texas star. Either way, amp input may need to be tuned better. You could try a different jumper length, it wont fix the problem per say but it might fool the radio into thinking everything is good
it's a solid-state 2 pill base amp
