Base case restoration
Magic Boy
Oct 19, 2008
91
11
18
Queensland, Australia
The Realistic TRC-490 I have has a scuffed and lightly scratched casing.
To re-finish this surface would make the radio look like new again.
Anyone have experience of this? I want to keep the same or similar finish.
Were these casings originally painted, or powder coated? Should I sand it back and prime with undercoat, as you would respraying a car panel? I hear sanding powder coat isn't a good idea.
I've seen other things painted with aerosol enamel paint, and it comes off in flakes on your hands!
If this is successful, I plan to do the same to a couple of other radios. The Navaho is the least valuable, and more easily replaced.
73's
For mobile radios you can buy replacement cases. Not sure yet about the TRC-490. If you can find a local business that does powder coating then you could see if they will do your cases. If so,then you would have to strip the cases of any coating. Powder coating involves 400 degree temps and adding an electric charge to the part to be powder coated.
