Base Coax Question
Mark Scannura
Sep 22, 2014
27
11
13
63
I'll be mounting an A99 to my chimney. Bottom of the 99 will be in the 23 to 36 foot range. I'll be using a 10 foot galvanized mast that will be sunk into the mounts about 3 feet. That will leave about 7 feet of mast above the top mounting bracket. For coax I have a 100ft run of LMR 400UF. My question is do I just attach the coax and zip line it to the mast in a straight run down? I see a number of references on the forums to using a choke or balun. Any suggestions?
