Beefy Battery Side Terminal Connector ?
Wire Weasel
Senior Moment
Dec 13, 2008
3,308
970
223
Hi guys,
I may need a better way to draw heavier current from my side terminal battery post. What are some ideas?
I currently use a heavy duty alligator clip onto the bolt head, and that works fine for my stock-low power radios. Thinking I'm going to need something more substantial than that for a high power radio.
What do y'all use? Thanks!
Cool man, thanks! I have an Absolute store in my town. I'll check and see if they carry something similar. This will do the trick.
don't even connect to the battery. follow the big red wire to the starter motor and connect at the starter. no corrosion issues and also a good "clean" power source.
be sure to temporally disconnect the cable on the battery side BEFORE you make the connection at the starter side..... it's always "hot":):)
Hi HDon6, My starter is too hard to get to and is above an exhaust pipe. Too much trouble. Have to go with the battery, but thanks anyway!
On the starter there is the heat issue. With the side post adapter you can mount a distribution block close to the battery and come from it to the block. Some of the blocks have fused outputs on them too so you can kill several birds with one stone.
BC
Many thanks for the tips & help guys. Got a gold plated extend-o-bolt at Absolute Audio today for $5.00. Just the trick!
