Beehive/gum drop mobile antenna mounts
psycho
Running a special on our rooms!
I Support WorldwideDX.com!
Aug 25, 2006
3,433
1,330
173
Floriduh
Is there one available that isn't a piece of crap? I remember Solarcon made a serious heavy duty one several years ago but I have not been able to locate one.
The Solarcon HWM-1 was hard to beat but like all good things seem to be.... DISCONTINUED.
Back in the 90's had one that lasted several years, even with my homemade coil antenna. I can't remember to save my life what name it was. Haven't seen any that style in the last 10 years that's worth a crap though. They all seem to break out within a couple months.
I personally don't care for gumdrop mounts, I use this for my mobile screwdriver antenna that weighs in nearly 2lbs and no issues running 3200 miles a week in a semi truck.
Do a Google search, I found one cheaper on Amazon.
Predator SOSTUD Heavy Duty Aluminum Antenna Stud
by: Predator
The best "gum drop" mount I found was sold by C C Distributors, Corona CA. It was made from molded epoxy, rather than injection molded plastic and is pretty much bullet-proof. The ones I have are light gray in color. I ran some pretty heavy antenna setups on my mobile, and never had one fail. They came in plain white boxes, so I have no idea who made them. I heard that C C's owner, John, passed away and I don't know if they are still in business. Check ALIEXPRESS, I found them advertised on ALIBABA
https://guide.alibaba.com/shop/ante...drop-3-8-24-stud-mount-w-so-239_61379440.html
- 399
antenna-gray-bee-hive-gumdrop-teardrop-3-8-24-stud-mount-w-so-239_23473318.jpeg .
check this mount
https://www.breedlovemounts.com/cb-ball-mount.html
61ffc37cfb1896046ed09cd494d63985
Reactions: fourstringburn
Breedlove may be expensive but you only buy them once. With the gumdrops available in the UK using them with my Little Tarheel they'd last about 4-6 months before I started getting issues. This is because these type of mounts rely on a brass press fitting pressed into the threaded section to provide a connection to the centre pin of the antenna socket and a lateral load from an antenna causes that press fitting to become loose resulting in an intermittent connection. A Breedlove mount costs several times what it costs for a decent gumdrop here however the Breedlove mount will effectively last forever so after 3/4 years its cost no more than buying cheap mounts and having to replace them.
Reactions: tecnicoloco
