A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
I am new to this forum, so forgive my basic question. Which would be the best antenna for a 32 ft Class A motorhome with a rubber roof. The body is fiberglass/gelcoat. We only use the RV 3-4 times a year and I want to add a CB..Thanks in advance for input.
If it has large side mirrors - like a diesel tractor does - then I would mount a 5 ft Hustler 'Firestick'. Mounted with a mirror mount. It should perform as well as they do on so many trucks that pass over our highways every day - using the same antenna. The Firestick is relatively inexpensive, easy to tune, and can be easily found most anywhere. It is a 'top loaded coil' antenna; which means that it should be pretty efficient. Get a high quality mirror mount and use a piece of decent quality coaxial cable. Then, set the SWR - and it should work quite well - IMO . . .
If it's a class A, the mirrors brackets are probably an odd shape that won't take a standard mirror mount. Do you have a ladder on the back? You could mount a mirror mount toward the top of the ladder and put a short 3' fiberglass antenna. You could also use something like a Wilson Trucker 2000 if you want to spend a little more. If mount it on the rear ladder, you can run the coax down the side of the ladder with zip ties, underneath the entire chassis and up into the cab somewhere. That's basically what I did on my class C. You will probably still have to run some wide ground strap from the mount down to the frame because the ladder has some type of coating on it that doesn't conduct very well.
