Big Flat Cat
Highway Man
May 18, 2019
362
433
TN
By Tram! Nice looking antenna, how does it stack up to the Predator 10K and Predator Competition Plus?
Might as well throw the Monkey Made MM4 into the mix.
Tram has been selling some decent looking antennas for a while now...unfortunately many are completely shameless clones of the 10k.
Can’t see any reason that antenna wouldn’t work just the same as (and no better) than any other 6’ center loaded antenna.
About the only way to make them perform better is to make them longer...but quality construction is a worthwhile consideration as well.
The antenna I would like to see made is a 10k/ 17”, with a 3 turn coil and a long soft whip. Should run about 8’ long, and offer some small improvements over the more common 6’ antennas.
