Rackmount Bird watt and vswr meter, used and untested. No slugs included.
Here is a pictues and specs (this is not mine but identical) because I am too lazy to find my camera.
Item # 4522, Single Meter - Dual Element and Selector Switch, Panel-Mount Wattmeter on Bird Technologies Group
Specifications
Power Range 100 mW to 10 kW
Frequency Range 450 kHz-2.7 GHz (depending on element)
Accuracy ± 5% of full scale
Insertion VSWR N Connectors 1.05 max. to 1000 MHz
Connectors QC Type - N (F) normally supplied
Nominal Size [inches (mm)] 19 x 5-7/32 x 1-11/16 (W x H x D)483 x 133 x 43
Weight 3-1/2 lbs. (1.6 kg)
I am looking to trade for SSB CB, 10m, 2m and 70cm radios and handhelds, freq counter, vswr meter for above 30mhz or other test equipment.
Will also take cash make offer.
Specifications
