Bird announces a new Antenna Analyzer
KG0MN
Mar 5, 2010
166
42
38
SK-4000-TC
The pocket-sized SiteHawk Antenna and Cable Analyzer operates from 85 MHz to 4 GHz and features an intuitive interface readily accessible to the first time user and minimizes clicks for an expert using it every day. Substantial internal storage eliminates the need to worry about file storage, holding thousands of traces on the device for future analysis or reporting. With the SiteHawk, it is simple to 1) Determine if there is a problem with your cable and antenna system using the Measure Match function and 2) Locate the source of the problem with the Use Distance to Fault measurement.
No HF because of the chip they are using - more or less a single chip solution. Hang on because these should start coming out in droves. There is huge margin on this product.
