Blown up, split in 2 finals?
338_MtRushmore
Jun 17, 2012
1,646
1,157
193
The Dakotas
I was away from my station over the holiday, and the fuse was blown on my optima when I turned it on. I replaced the fuse and it let smoke out. What in the world might have caused this?
Now that I think about it, it did receive for a second or 2 after I turned on the power supply. When I replaced the fuse, the negitive was disconected, but started smoking as soon as I started screwing the fuse holder together. I'm guessing lightning?
Oh well, at least it wasn't a good radio. I guess I will need to get everything grounded before I get another radio.
Oooops :)
Isn't it fixable?
There isn't anything that can't be fixed, unless the entire unit has been converted in to carbon. A schematic and a parts list will help a lot.
I repaired a radio that had a crack running through the center of the circuit board. From one end all the way to the other. The radio as given to me as a challenge which I passed. A lot of work for a cobra 19.
Ouch.... Very possible like I said, but was not 100% sure... When you get a new radio just make sure you double and triple check everything and make sure you got good grounds.. You do not want another radio making its way to the dumpster... Anyway, sorry to hear about your radio, good luck...
I'll give you $5.00 dollars and pay shipping for it. I'm serious! I would use it for a video on soldering and repair of surface mount circuit boards.
I am not familiar with the layout of that chassis. But if it is anything like the 257 Magnum; then the AM Regulator should be mounted on the right side of the frame rail.
Got a picture?
Reactions: 338_MtRushmore
  • @ W4KVW:
  • @ W4KVW:
