build a power supply?
dejaskysdad
May 21, 2013
16
39
I found a big transformer its got a numbet on it ats7205 does anybody know how to wire it? Can it be used for a power supply ? Any help and info would be greatly appreciated
Big transformer
Survey says:
Pioneer Electronics (USA) Inc. Parts & Accessories Online - Part Number: ATS7205 Information
It appears to be an XFMR from a receiver.A little research on the wires or terminals will reveal what voltages it has.<Usually>,the 2 wires together is primary and multiple wires are secondary.If all wires are together,then try to separate by wire color or size.Certain MFRS use a standardized wire color coding which shoule be researched B-4 power is applied. Transformers contain a lot of smoke just itching to be released.:tt2:
