carrier on ssb??
9Lives
182
7
42
I have a couple questions. When I turn my mobile amp OFF with my galaxy 959 it has a carrier on ssb and swings backward. When I turn the amp on it corrects it self. Is this due to coax length and swr? Or spurious emissions need to be tuned out? Thanks in advance!
You might turn the mic gain down, sometimes room noise will look like carrier wattage when you key the mic in SSB mode but don't talk. After this check the radio by itself to rule out a bad jumper. In the end if you actually do have a carrier present on SSB then your radio needs fixed.
