CB Sticker Sales
That really looks great!!
I really like the control knobs you used. Did you get them off a parts radio, or where you able to source them new?
Thank you !
Ebay. PITA to find a matching set to fit dual pots and ch selector. Echo board is doa so I'm having a member here switch some pots around to match the faceplate.
I need to find a gold bezel or someone who can plate my scratched up spare, haven't had any luck with the gold bezel. Ranger PT148N010H.......
How are their decals applied? In other words, do they have a sticker backing or are they vinyl that is applied with water? In my experience the ones that contain printed paper will start to curl and shrink under fluctuations in temperature and humidly, especially when used in the mobile. Shortly after Deb retired I bought a decal from another source (not the one you mentioned) that failed within a year. Since then I won’t mess with anything unless the decal is vinyl that is applied with water, same as window tint. Some say they are “vinyl”, but only as a protected layer on top.
Reactions: Cabover Bob
    63Sprint has left the room.
