Channel Master beams.
Staybolt
Sr. Member
Mar 20, 2013
1,098
458
113
I got me a set of 4 eleiment channel master beam antenna yesterday. The guy told it it was a Channel Master but i haven't found any info online about it as id like to get some directions on it.
Describe it along with number of elements,element lenght,feed line junction
Or better yet, upload a photo
P.S. there is info on the web for converting tv antennas to two meter.
http://www.arrl.org/files/file/Technology/tis/info/pdf/9611034.pdf
http://www.eham.net/ehamforum/smf/index.php?topic=45840.0;wap2
6m/2m/70cm Yagi Antenna (Part 1/9) Built from Old TV Antenna - YouTube
Since this is the CB section and the Channel Master line is (was) a ready made product the TV antenna to 2m is waaay OT.
Try google but i have never seen or heard of channel master beams....:crying:
You had to be around in the 70's to remember the Channel Master line. It sounds like the OP has the Channel Master Signal Tracker antenna. Check out the vintage ad on CB Tricks below. Getting a manual for it may be tough.
Channel Master "Signal Tracker"
Channel Master was a brand of antennas back in the late 70`s.
They were known for the goofy delta-wing antenna that they made called the power wing but they made other antennas.
Mobile antennas, base antennas, a 1/4 wave, 1/2 wave and 5/8 antennas as well as the signal tracker 4 element beam.
Speak of the devil...............
Channel Master "Power Wing"
The second base antenna i even used was a channel master. It looked just like a starduster but was gold in color.
The beam comes in 3 boom sections and the elements all fold up much like a TV antenna. Very cool! I need to rebuild the gamma match and get all new hardware but overall its in decent shape.. I don't know id ill keep it or not, as one of my radio friends was asking me the other night about putting up a beam.
The elements have a very slight gold color to them.... Its faded but you can still see it..
Sounds like it would be a good antenna for hilltopping with the fold out elements.
    boog351 has left the room.
