I have a couple questions about SWR readings. Any help is appreciated.
I have my meter hooked up as follows: radio output to amp input/amp output to meter input and meter antenna to antenna. Radio and amp are powered by battery, antenna mount is grounded to truck bed and frame, truck bed and cab have ground straps to frame. Radio is a Galaxy DX959, antenna is a Tram TBC-12 Bigcat, all coax is RG-8x. I had the same set up in a truck I sold. This is all the same equipment installed the same way in a new truck.. I was able to get a 1.1 Swr reading on the old truck at the Dosy meter with amp off. Just wondering if I should be concerned about the different Swr readings. Any help appreciated. Thanks
Readings with amp hooked up and power off.
Swr reading using radio meter CH 19 is 2.0
Swr reading at the Dosy meter is 1.5
Readings with amp hooked up and power to amp on
Swr reading using radio meter is 1.3
Swr reading at Dosy meter is 2.5
