Cleaning your Astatic
Wire Dawg
124
35
38
Recently bought a D-104 (chrome lollipop) that has some stains & rough areas. Since the mic works well, I'd like to restore the shine of the chrome areas. What product(s) do you recommend? Is there a tried-n-true chemical that will clean without damaging the chrome surface? Will water/ soap do the trick?
I have quite a few chrome D-104's that I prettied up so I might be able to help. I also have a chromed out Harley Super Glide Custom so I can clean me some chrome..:D Post a few pics of the "stains and rough areas" and I might be able to suggest something. You can't remove pitting or areas where the chrome is gone though.
What I normally use to clean up chrome is lemon pledge. Works like a champ and leaves a fresh lemony scent. LP also works great on painted surfaces as well.
Reactions: 2 people
Appreciate all comments, including the snarky one. Lemon Pledge on a cotton ball did the trick beyond expectations (looks like new). WD-40 was highly recommended by a coworker today, but I won't try it until I have to remove the tougher residuals of 'Redman' (I wanna be a comedian after leaving the force).
It works. Here's why. From another forum I belong to.
For the purpose of this discussion, I will list the information relative to Pledge in the aerosol spray can as it appears to be the most common used by others on this forum.
The base ingredients are:
1. Naphtha, petroleum, light alkylate 5%-10% or (isoparaffinic hydrocarbon solvent)
2. Polydimethylsiloxanes (Silicon oil) 5%-10%
3. Water 70%-85%
4. Butane1% -5%
5. Isobutane1% - 5%
6. Propane1% - 5%
Now we can breakdown what these are and what they do.
The first ingredient is:
1-Naphta,petroleum,light alkylate.
This is a hydrocarbon solvent-based dispersant formulation which combines oil penetrability. In other words remember the label says "smear and smudge proof"? These are the ingredients that will break down and remove the smears, finger or dermal tissue oils. Criminals take note.. use this to eliminate finger prints. Just dont be a dumb (EDITED) and leave the can behind!!
Now, what is a hydrocarbon?
A general term for organic compounds which contain only carbon and hydrogen. They are divided into saturated and unsaturated hydrocarbons, aliphatic (alkane or fatty) and aromatic (benzene) hydrocarbons. Crude
oil is essentially a complex mixture of hydrocarbons.
To break it down even further, I will now define an organic compound.
An organic compound is any member of a large class of chemical
compounds whose molecules contain carbon.
What is carbon you asked? I knew ya would!!
Carbon is a chemical element with symbol C and atomic number 6. As a member of group 14 on the periodic table, it is nonmetallic and tetravalent (a state of an atom with four electrons making four electrons available to form covalent chemical bonds.)
A chemical element is a type of atom that is distinguished by its atomic number; that is, by the number of protons in its nucleus. The term is also used to refer to a pure chemical substance composed.
What does this all mean?? It is a pure chemical substance.
Why is it in there? Remember the finger print? It is a solvent that removes oily residues. This is the cleaning agent in the product.
Look at the can.."It dusts and cleans". this is what makes it clean/remove dirt,grease,oil,grime.
That was the more lenghty one. The remainder are relatively simple. If you are still reading at this point, thanks for bearing with me.Go grab another beer! I will summarize at the end and compare to other products on the market in terms of ingredients, costs and results.
The second noted ingredient is:
2-Polydimethylsiloxanes or Silicon oil 5%-10%.
This is silicone based oil. The molecular structure of this is such that friction is significantly reduced. This nifty additional ingredient is also the reason why the ..refer to label again.. NO WAX BUILD-UP!! Silicone will blend with it'self and not mix or layer with other chemicals.
It does however have the ability to **** bike painters off due to the fact that it needs to be completely removed proir to coating with paint. If not...start all over again. It makes surfaces slick so that nothing sticks. It also provides the shine to the surface.
This chemical is also present in 95% of products us bikers use on our scoots such as Armor All, Meguires Wax and STP Son of a Gun just to mentiion a few so if you are worried about using Pledge in the past on your bike, you may alraedy have and just did not know it.
This silicone oil is also an ingredient in Right Guard deodorant, baby powder,Desitin, Gillette Dry and several moisturizers and creams. This is why Pledge does not contain wax, they use this instead.
Makes me want to try it with the goa....wife!
To the guy that posted about the fella steping on his fender and sliding off...about to 5 drops of this in a drink will cause lets just say possible incontenence" which will then require the need for additional Desitin with the same ingredient to help that diaper rash from the copiuos ammounts of passing solids!!! Great stuff ain it?
The third ingredient:
3-Water. This acts as a dilutor. Kind of like "filler" in cheap dog food but in liquid form.
Cant use the product undiluted.
The remaining butane, isobutane and propane are the propellants that assist in expelling or propelling the liquid product from the can. The methane is building under pressure and the propane, butane provides the ignition source. Kinda like putting your tounge on a 9v battery. You know you are gonna do it eventually when no one is looking. Try chewing aluminum foil!! Nah...dont do that either.
Other ingredients such as aromatic compound like orange, lemon or any other organic scent additive can also be incorporated.
Now with this little snippet of knowledge, how does one apply it to everyday living.
If Martha Stewart says that a prison panty liner work just as well as a microfibre cloth stop reading. If not..please bear with me for I am almost done.
Several products out there are costly for several reasons. 1 because of proprietary ingredients/raw materials, 2 advertising costs, supply and demand and product to market costs. What will the market bear? I have always compared ingredient when shopping. Silicone oil is silicone oil, Pepto Bismal, for the guy trying to stand on the fender coated with silicone oil is pink Bismuth...same thing!
Pink bismuth is MUCH cheaper.
I heard of a product called Plexus. A great cleaner and conditioner for Lexan. At $15.95 for a 13oz can versus an 18oz $4.99? can of Pledge? I have not bought or used Pledge and do not know the actual cost I am sure it is not even close to this other product.
In summary:
* Will not damage finish
* Will provide a nice shine
* Will not build up or layer
* Safe on windshield. No alcohol or amonia
* Safe on chrome
* Also has some (although not real good) anti corrosion properties. I use Boeshield T-9 for this application.
One precaution!! Flammable! Do not use around open flames or on hot pipes or other hot components. Do not get on or use on denim ar matted finishes!!
It is truly amazing. Since you mentioned owning multiple D-104's, I'd like to tell you about a very efficient CB shop by the name of Precision Communications, exit 163 in Dickson, Tn. If you ever need one, they have replacement elements for the old Astatics, in stock. Good and honest people to deal with. Again, thanks for your feedback.
I was just in Dickson this week. And Memphis, and Lyles, and...... I travel a lot for work. Always keep an eye out for a CB shop to stop in and take a look around, but I missed the one in Dickson. Thanks for the tip, I'll drop in next time I'm out there.
And I have always just used Windex on my D104's. Although I think I did use polish for my Silver Eagle. I'll have to try the Pledge next time.
73,
RT307
