Cobra 142 GTL
I wonder if I put in another varactor in paralell with CT3 if that would give me more tuning range...
That varactor mess needs to get removed, don't just add to it. Take that SMD crap completely out of there, a friggin' LED light would make a better varactor than whatever that combination is. And get rid of that electrolytic cap on the filter. It only stiffens the VCO control voltage and makes it respond slower.
  • Haha
Reactions: vswr
No problem. I peel that crap out in the morning.
Reactions: brandon7861
If radios could talk, this thing would jump into your arms begging for help. If we had a name to go along with the work, I would nominate this one for the 2026 golden screwdriver hall of shame. If you get this one going, it will surely treat you well for the rest of your life.
  • Haha
Reactions: vswr
Yeah. Its going back on the shelf once fixed. This is what people did pre- export radio days. Added a watt or 2 and lost their mod, pull out a few parts to get screeching mod, mess with the switches and install a bunch of uppers and lowers, then to really screw things up for the next guy, just add in a few more parts, change some others and remove some. Fun huh!!!!
The radio talked to me today. It told me to remove that black box, remove the cap underneatch and repair the cut run, and remove that electrolytic cap, the start the tuning process over again for the 7th time and I will fial in perfectly. Its working great! Thanks for all your help. Soon I will be working on 1of my 2 motorola 555 crap boxes transmits fine but in rx it pins the needle and there is zero receive. Stay tuned!
Im wondering if the display the same as the cobra 25 or 29? I need a 16 pin, 8 top, 8 bottom, center pins common, and common anode. I got a lot of 25s snd 29s snd 148s. Let me know. Thanks.
Edit: cobra 25 Ltd has the correct pin out and common anode configuration. Only difference isvthe color but its working and looks great!
Did me some good reading about broadbanding methods. This was how it was done.
