cobra 148gtl with usb&lsb
donemad
104
2
26
is my power supply strong enough to power it? it seems it gets very dim , but other radio,s work fine on it .........power supply is a pyramid 13.8 vdc. with 2.5 amp constant.just dont under stand it.......when you key up & talk it gets dim like mod. backwards.real bad .like not enough power.hlp. plse.
Your guess is right :( a good 5 to 7.5 power supply would be much more sufficient , especially where SSB is concerned. Although the 2.5 should be OK for AM only , but in your case , sounds like yours is on the blink. :( Good luck to you
that 148 will pull about 2 to 3 amps on transmit. thats if its a stock radio. probably more if its been doctored up. like switch kit said. id go with a 5 to 7 amp power supply. i used to run mine in the house on a 10 amp.
